clutch cable and rear main oil seal?
Old Jun 3, 2009 | 08:52 PM
kosman's Avatar
kosman
sideways all the way!
Default clutch cable and rear main oil seal?
as above can anyone tell me best place to get them from?
the clutch is a alcon paddle clutch.
is it worth changing the oil seal while the box is out?
also my power steering feels heavy,plenty of fluid in it, or is it because i dont use the car that often? and my daily driver has got real light steering
Old Jun 3, 2009 | 09:01 PM
Mike1's Avatar
Mike1
The power steering on my 2wd Sapphire certainly has more feel and weight than something like a 3-series BMW - remember the Sierra rack is a fair bit quicker so it would need more assistance to feel the same weight as a car with a slower ratio
Old Jun 3, 2009 | 09:53 PM
kosman's Avatar
kosman
nice one,did think it might just be me.
Old Jun 3, 2009 | 10:17 PM
AndyPen's Avatar
AndyPen
I would change the seal whilst you are there. They do go and its an easy job if the box is out already.
Old Jun 3, 2009 | 10:43 PM
kosman's Avatar
kosman
will do then,any ideas on where to get them and what clutch cable i need?
Old Jun 4, 2009 | 05:46 AM
I would give Matt Lewsi a ring first, 01543 484488, if not still get them at ford afaik.
For the rear seal I would try and get a Viton, massively tougher and better.
Old Jun 4, 2009 | 09:01 AM
Mike1's Avatar
Mike1
If you've got EBAy capability, Matt Lewis delivers them to the door for Ł25 all inclusive
http://myworld.ebay.co.uk/matt-lewis-m-sport/
Old Jun 4, 2009 | 10:27 AM
kosman's Avatar
kosman
nice one lads,got my thrust bearing off this dude,seems sound like
Old Jun 13, 2009 | 11:39 PM
kosman's Avatar
kosman
put new clutch cable on today,difference is amazing,really light now.
Old Jun 14, 2009 | 08:42 AM
Don't get used to it, as they don't stay that way too long, the teflon sheath surrounding the inner cable chafes and starts jamming up the cable!!
Old Jun 14, 2009 | 10:26 AM
AndyPen's Avatar
AndyPen
I know you are keen on these mate - any supplier info please?
Old Jun 14, 2009 | 03:39 PM
kosman's Avatar
kosman
bastard,ill have to set up a monthly direct debit to matt lewis for clutch cables
Old Jun 14, 2009 | 06:27 PM
I have to get them from a seal supplier by number, the 3 set number on the seal itself.
They're good seals and are designed for high temp work, but around 2-3 times the cost of std ones.
This is inside diametre outside diametre width, unfortunately not all sizes are available, as mainly used on industrial machinary.
I don't know the seal number of this so can't even say if available.
Old Jun 15, 2009 | 08:15 AM
Mike1's Avatar
Mike1
A new one makes a big difference doesn't it?!
Wilsfoci
15
Mar 30, 2016 10:26 PM
Chas
Sep 21, 2015 08:57 PM
Danielbetty
Aug 28, 2015 08:01 PM
muz
Aug 16, 2015 12:57 PM
st220kyle
16
Aug 14, 2015 06:13 AM
