sounds like a f***ing bus!!!
Old Jun 2, 2009 | 10:47 PM
Moonstone Mo's Avatar
Moonstone Mo
Default sounds like a f***ing bus!!!
rite, i have been running the standard plastic dumpy on the tb side but it had split so i swaped it for a shitty what i think is a piston type one but now it just hisses really really loud..if i was to put it on the airfilter side would it be quieter and would i get my chatter back?
cheers.
Old Jun 2, 2009 | 10:50 PM
BigErn's Avatar
BigErn
would there be any point putting it on the air filter side? The air will have already have came back through the turbo blades before it gets released by the valve wont it
Old Jun 2, 2009 | 10:51 PM
BigErn's Avatar
BigErn
What turbo and what boost pressure do you run?
Old Jun 2, 2009 | 10:52 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
isnt chatter compressor stall??? if so, isnt a dumpvalve meant to prevent compressor stall and therefore no chatter sound
Old Jun 2, 2009 | 11:13 PM
Moonstone Mo
t3 hybrid,360 bearing,cut backs running 23psi
Old Jun 3, 2009 | 07:42 AM
If you want chatter just run without a DV, putting it on hot side is not likely to make it any different noise wise.
Old Jun 3, 2009 | 08:01 AM
Moonstone Mo
thanks people.
how about runninga re circulating one again just not the standard plastic one.?
Old Jun 3, 2009 | 08:04 AM
Moonstone Mo
whats the bestway to blank off the vac pipe.
Old Jun 3, 2009 | 11:03 AM
focus 4x4's Avatar
focus 4x4
Do away with the dump valve completely!
Old Jun 3, 2009 | 11:24 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Remove the T-Piece and have your boost gauge connected directly to the manifold.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
ward1174
Sep 12, 2015 03:34 AM
