Leather interior
Hi i have a 2wd saff that has had the 4x4 leather put in it and the roof lining has started to sag so i have taken out the roof lining and ripped it all off i know a trimmer who is going to help me re trim it but i'm just woundering what the original coulor of the roof lining was in a saff with leather interior.
cheers,
Phil
cheers,
Phil
cheers,
Phil
cheers,
Phil
Steve
i just took my time and pushed it on with a sponge to prevent getting fingure marks in it only tip i give you is get a high temperature spray glue, sharp sissors and a sharp blade i'll put up a pic of the lining in a mo. any qustions just ask.
cheers,
Phil
cheers,
Phil
Holy crap!! You done that yourself?? Impressive!
I tried it too but getting the right material and glue was a right nightmare. Ended up getting it done because I failed miserably. The only cloth that kind of looked like the original material wouldn't stretch into the corners enough, the glue made stains in the surface etc. Then I tried vinyl but it got very lumpy, all the bumps and holes in the material underneath showed right through.
