Idle Co%
Old Jun 2, 2009 | 12:34 PM
RST_Rob's Avatar
RST_Rob
Default Idle Co%
Hi all im having troublestarting my rs recently with the weather getting warmer etc, basically what happens is the car starts for a split second then stops then i have to crank it over for ages before it fires up. Ive recently fitted brand new injectors and coolant temp sensor and the only thing left i think it could be is the idle co.
I checked the co reading at work and found it to be at 5.5% i have adjusted it down to 3.5% and seems better/quicker to restart but just woundering if anyone knows what it should be/ they are running themselfs?
Cheers in advance!
Old Jun 2, 2009 | 05:45 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
am running 2.5 %
Old Jun 2, 2009 | 05:59 PM
RSmark84's Avatar
RSmark84
im running 0.3%
Old Jun 2, 2009 | 06:23 PM
studabear's Avatar
studabear
mine was 1.5% at mot
Old Jun 2, 2009 | 06:28 PM
ROB7656's Avatar
ROB7656
3.5 is max to pass mot mine was 6 but adjusted it down to 3.5 to pass MOT...5.5 wouldnt cause it to stall it is just a bit rich.
Old Jun 2, 2009 | 06:31 PM
ROB7656's Avatar
ROB7656
i rang my tuner to ask his advise before i let my MOT guy touch anything and he said that it was 3.4 at my last set up. gotta love mfi
Old Jun 2, 2009 | 06:53 PM
RST_Rob's Avatar
RST_Rob
yeah i remeber when i had it set up first time round the guy set it to 3.5% and was ok then and told me i had a weaping injector on cylinder 4 so now have 4 new ones and still the starting issue so didnt know if 3.5 was still abit rich as running out of ideas of what is causing it? i know the tps is working as it clicks when the throttle is pressed and really am stuck! like ya say good old mfi lol!
Old Jun 2, 2009 | 08:47 PM
ROB7656's Avatar
ROB7656
check your timeing mate,or get it checked
Old Jun 2, 2009 | 08:49 PM
anvini's Avatar
anvini
Cheers in advance!
Hi mate!!
I had got cold starting problems last week and solved it increasing idle speed with idle screw.
I noticed that the speed idle was low.........
Now the car starts at first key turn in cold and warmed.
Old Jun 2, 2009 | 08:57 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Rob I just had a thought mate!
Could well be your auxilary air device, it lets more air in for a cold start up and if it doesnt then you'll be really rich, as the weather is warmer the air is thinner so might have been alright in the winter but now it needs that bit extra air or it chokes itself!
Old Jun 3, 2009 | 06:51 AM
RST_Rob's Avatar
RST_Rob
Cheers mate hadnt thought of that, wil have to take it off tomoz night and see if i can give it a clean or if its completely fubar. See you tonight dude!
Old Jun 3, 2009 | 02:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate see you then!
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
