Blue Smoke?
Old May 31, 2009 | 11:06 PM
Matt-Turbo's Avatar
Matt-Turbo
Question Blue Smoke?
When i start my car up and just let it tick over its fine for a minute and then a puff of blue smoke comes out then you give it a rev and it clears this only happens the odd time. Wierd thing is that i only have the engine run in? Any ideas?
Old Jun 1, 2009 | 11:06 AM
morph's Avatar
morph
Has the engine been fully rebuilt or just bottem end?
could be a valve stem seal but they should have been replaced on a head rebuild.
Old Jun 1, 2009 | 11:41 AM
rstel1's Avatar
rstel1
as said above or maybe the turbo
Old Jun 1, 2009 | 04:00 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Also did you clean IC, metering unit, and boost hoses out?
Old Jun 1, 2009 | 05:59 PM
Matt-Turbo's Avatar
Matt-Turbo
I was told the valve stem oil seals were done and its a band new t34 with 360 trust bearing. But maybe i got lied to lol cause it seems like oil seals as yous say cheers man
Old Jun 1, 2009 | 06:00 PM
Matt-Turbo's Avatar
Matt-Turbo
IC metering unit???
Old Jun 1, 2009 | 06:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Intercooler, Fuel Metering unit, or are you EFI?
Could be that there is old oil in the IC (Intercooler), or a puddle sitting in the metering unit if your still MFI.
Old Jun 1, 2009 | 06:31 PM
Matt-Turbo's Avatar
Matt-Turbo
Im efi mate o sorry didnt catch on lol that would be worth a look cheers man would it clears its self eventally? Will i just take the ic pipe off and have a look then
Old Jun 1, 2009 | 06:38 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Right cool!
Yeah if there was anything worth worrying about in the IC I would think you'd be able to see it quite easily.
Old Jun 1, 2009 | 06:44 PM
Matt-Turbo's Avatar
Matt-Turbo
Ok man cheers and if not do you think it could be seals?
Old Jun 1, 2009 | 06:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
TBH it's really hard to say as everything is new
Old Jun 1, 2009 | 06:57 PM
Matt-Turbo's Avatar
Matt-Turbo
Hope its somthing simple like the ic
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
