Fuel lines on saph 2wd
Does anyone know if those nylon fuel line pipes that goes from the tank to the steel pipe (return) and from the pump to the steel pipe are still available at Ford?
Me Cossie Runs Atlast!!!!
I was told they werent by my local dealer but that doesnt mean to say any of the dealers in the UK dont have some lying around in their store room somewhere.
If the pipes are not available anymore, is there possible to get hold of braided 8mm fuel hoses? I want 8mm so I don't need to change all the fuel clips.
Was at Ford today but no change in hell getting those pipes, empty everywhere. So I guess I must think off another way to sort this problem then.
So...anyone got ideas? Would be much appreciated
Hi you could brace some steel -6 fittings to the steel fuel line and then use some goodridge hose and fittings !
I was thinking of braided hoses myself but the smallest size you get here is 11 or 12mm OD and then they wouldn't fit in the original fuel/brake clips. I've seen that you can buy 8mm nylon pipes but is there possible to bend and shape them just like the originals? Any special tool or technic?
Sorry, I meant the nylon pipe that goes from the filter to the steel pipe, not from the pump. But does anyone know what kind of connectors I can use between the steel pipe and hose on the pressure side?
