hybrid T3 4x4 saff
Old May 30, 2009 | 08:11 AM
GUZZLER's Avatar
GUZZLER
Default hybrid T3 4x4 saff
Hybrid T3 from a 4x4 saff, only done a few thousand from new, was then checked over & rebuilt, not used since.. spec is 60 trim comp wheel, 360 thrust bearing & large collar, mint .48 exhaust housing with double bar crank arm. Housings are loose so it would be easy to adjust for 2wd, 4wd or RST (it was bolted to an RST last time) £300
can take to classic ford if needed.
Old Jun 3, 2009 | 07:38 PM
GUZZLER's Avatar
GUZZLER
Old Jun 3, 2009 | 08:25 PM
GUZZLER's Avatar
GUZZLER
Old Jun 8, 2009 | 12:49 PM
GUZZLER's Avatar
GUZZLER
up
Old Jun 8, 2009 | 01:14 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Hmmm....bodywork, or turbo... Not fair
Need bodywork so that I can use the turbo
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
