XR3I running problems......HELP please
I have a ford escort on a K plate fitted with an EFI engine 1.6i. When starting the engine works fine but as soon as the choke is the idling is irratic and sometimes cuts out. It can be a pain to start again but does go. I have changed the Lambda sensor and the sensor on the side of the throttles control block...................can any one tell me what the possible problem may be. Thanks
Eigdoog
Sep 13, 2015 05:46 AM
