Saphire cosworth with stage three chip missing?
Old May 26, 2009 | 10:05 AM
Ozzymc's Avatar
Ozzymc
Default Saphire cosworth with stage three chip missing?
Have a 00 Saphire 4x4 it has stage three chip,green injectors map sensor the lot. If you floor it,it will not take it,if you ease the pedal no problem would it be the fuel am using 95 octane
Old May 26, 2009 | 10:16 AM
jon@work's Avatar
jon@work
Originally Posted by Ozzymc
it will not take it
what do you mean by that ?
Have you changed the fuel filter recently ? If not, do so.
Have you checked the fuel pump voltage or rewired the pump? If no, do so.
Old May 26, 2009 | 10:30 AM
Ozzymc's Avatar
Ozzymc
If i put my foot to the foor it holds back like it is missing but if i ease the pedal down there is no problem.I only have this car not even 200 miles on it.I was told it was serviced but i will check the filter.
I had this problem with a previous one and if i remember it was wiring at the bulk head or a bad connection with plugs there would this be correct?
Old May 26, 2009 | 10:51 AM
Paul_RS's Avatar
Paul_RS
Check you fuel pressure reg isn't goosed.
Check the fuel filter isn't blocked.
Contact clean the engine loom multiplugs just behind the head. If they get moisture/dirt in the they can cause a missfire.
Old May 26, 2009 | 10:59 AM
jon@work's Avatar
jon@work
If after you've changed the filter and checked the fuel pump voltage (and the bulkhead connectors as said above) and the issue is still there, then see if you've still got the problem if the fuel tank is filled more than half full - sometimes the internal feed to the pump inside the tank gets blocked, meaning you'll need a new fuel tank.
Old May 26, 2009 | 11:21 AM
Ozzymc's Avatar
Ozzymc
Thanks lads will try all of the above as soon as i get the wheels back.
thanks for your help
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
JasonPD
21
Aug 20, 2015 07:36 PM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
