what are all the differances between a 3door and a rs 500?
lower lip spoiler and extra bit on top spoiler. Slighlty uprated supsesion, t4 turbo,rs500 intercooler,8 injector set up but 4 used in road cars, bigger plenum, bumper splitter, orange air hoses on the rs500. I think thats it?
different front bumper (top edge has air inlet) and lower splitter. had grilles in place of the front fog lamps
different top rear spoiler (has an upward lip on the edge)
lower rear spoiler fitted
rear suspension had some extra mounting brackets fitted(but not used on road cars)
8 injectors
t4 turbo
bigger inlet pipes
different intercooler
different engine block (stronger)
car had an extra 20bhp on production cars
think thats it!!
8 injectors
t4 turbo
bigger inlet pipes
think thats it!!
Front bumper differs in two places, the cut out bit below grill and also the 'scoop' either side of the number plate.
Also had a safety switch on the electric aerial. This was for the lower boot spoiler, when boot is opened the aerial would go down as it would catch.
pin stripe.
pin stripe.
Do you know what the differences were exactly? The revised mounting points for 8/9 degree trailing arms weren't used on road cars.
I was aware that they had moved to the different front ARB ( H14 type ) by then to give an extra degree of caster but I thought the later 3-doors had those on as well? Or were the non-RS500 3-doors that had them fitted all retro-fitted rather than in production?
I know that some dealerships changed 3-doors to the later front hubs to reduce 'straight-line nervousness' but only ever heard of it being done at customer insistance on cars that had already been sold.
The pre-release 3-doors had solid plastic inner TCA bushes and different gearing on the TRW steering rack gears but they changed them for mainline production after unfavourable reception from journalists on the launch.
500 difence is i have one and some just dream i have no job and still keeping it my dream car
but feels slow even 450BHP version !!
and sure this has been arepost AGAIN
And the hoses were bigger not just ORANGE !!
And some don't dream about the RS500 and see it as nothing more than a badged up special, bit like a popular plus instead of just popular, certainly doesn't warrant any more money from me.
I just can't get my head around buffty people who lock thier car in the garage and never use it, except for cleaning and polishing.
There are loads of differences
different thermostat housing
different rad hoses
different boost hoses
different alternator bracket
alternator drop bracket
inlet manifold
turbo
fuel reg
intercooler
bumper
spoliers
rear beam
probably lots i missed.
different rad hoses
inlet manifold
turbo
fuel reg
intercooler
bumper
spoliers
rear beam
Dont think anyone has mentioned the oil pump and delivery system btw? There also some bracket differences and bits and bobs like that.
Paul Reg did start a thread here...
http://fordrsforums.co.uk/viewtopic....fef573a#p12563
Basically its a set up ready to be abused with little effort - lol. See next Fast Ford mag for details
Unfortunately you've just come across as a right cock mate
I doubt it was your intention but it doesn't read very well.
The difference between the 2 is that you own 1 that others dream of? wtf
Not an unusual mistake to make Tab - the badges that you see fitted were designed for MG cars and not Fords mate. Most of us have retro fitted something but Tickford never did it. (I am the rs blokey in the Tickford club btw - thats how I found out)
I thought the plagues fitted to RS500's were actually issued by the RSOC and not fitted from new could be wrong tho.
The battery tray was modified to allow the extended plenum and fuel rail to be fitted. All the RS500s were RHD, and were originally supposed to all be black, but the work experience boy was on, so some White and Moonstone ones found their way into the '500 pen'.
The aerial was automatically retracted when the boot was opened (well, unlatched), otherwise the lower spoiler would bend or break it.
The 8 injectors were fitted, but the secondary set were not connected to the ECU. The L1 ECU was the same as the 3 Door's ECU, but with a map suitable for the T4, and 4 yellow injectors.
The 205 YBD block was specially cast for the RS500 and was not a regular production item, as with the 205 YBB blocks.
The fog lights were supplied as a dealer installable option - the customer could choose whether to have the brake cooling duct grilles installed at delivery instead. The front splitter was also installed at the dealer, so that it wouldn't be broken as the car was taken onto and off the transporter.
Did you know that all the RS500s had to have new water pumps installed because the originals corroded? They were left idle, outside, for 6 months after they were originally built while the designs and delivery of the new body parts etc were finalised and consequently installed.
I thought it was because they dilly-dallied on the colour that thay ended up with a few white and moonstone ones as Genk hadn't got 500 black bodies available in time?
Let me check my horse's mouth
As we already know, out of the 5500-odd that were built, 500 were shuffled away to a storage plant....I'll finish the story when I get back.
More info from the Horse's mouth, aka Mike Moreton who was put in charge of the Sierra Cosworth 'evolution', ie, the RS500. You'll find this in a fantastic book called Rallye Sport Fords - The Inside Story, incidentally, by Mike Moreton. There's a stonking big chapter about the RS200 too.
500 black ones were requested, but a handful of White and Moonstone interlopers slipped through the net. They were stored at Frog Island in Essex, one of Ford's holding areas where they waited, still in '3-Door' form. They then got shipped off to Tickford at Bedworth for conversion. The parts that were swapped, like the front bumper, intercooler, etc, were sent back to Ford to go in the spares bin.
Mike - aint got my copy yet - out tomorow as per my 1000 post - cant wait
I know they used the later H14 ARB as distinct to the early 3 door which used the H13 ....but seeing as the RS500s were made from later 3-door cars, the later non-RS500s had the H14 as well. Wasn't sure if the guy was referring to that....which obviously added an extra degree of caster
Good info cozmeister!
another fact,a few folk who had a sierra back in the day had an rs500 that they smashed and it had 500 bhp at least.the amount of times i have heard that old chestnut.
All were right hand drive, because they would only be sold by Ford UK. There's no such thing as a left hand drive RS500. The ones that raced in the BTCC were merely converted to RS500 spec, ie, the suspension, bodywork and engine changes.
wowk
Mar 30, 2021 07:49 PM
SMILER258
Sep 28, 2015 09:04 AM
