rst and no boost!!!
May 25, 2009 | 09:00 PM
rst and no boost!!!
hi people, i fitted a second hand turbo 2day as mine is in need of a rebuild anyway got it all plumbed in and left it ticking over for a good 10mins. Then went for test drive and there no boost at all iv checked for leaks and nuffin anyone got any ideas.
cheers jay
May 25, 2009 | 09:02 PM
Problem with actuator, bleed valve (if fitted), amal valve or the turbo is shagged. My bets anyway.
May 25, 2009 | 09:19 PM
it dont have a bleed valve and it boosted fine with old turbo think im going to re fit old 1 and see what happens.
May 25, 2009 | 09:21 PM
but how could i check to see if its the actuator
May 25, 2009 | 09:28 PM
is the actuator rod actually connected.if its not it will drive with not one bit of boost at all
May 25, 2009 | 09:33 PM
yeah its all connected up its just puzzling cause there no play in the turbo all pipes are connected just no boost not even any attempt or smoke
May 26, 2009 | 06:33 AM
is it the same actuator that u took off the other turbo? or a different one
May 26, 2009 | 08:10 PM
same one there is no play in the turbo but could it still be blown
May 26, 2009 | 10:08 PM
I spose it could be seized?! Have you spun it round by hand?
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
