HELP need info on Cosworth WRC Zetec piston YC1330
Old May 22, 2009 | 09:53 AM
focusracingaustralia's Avatar
Default HELP need info on Cosworth WRC Zetec piston YC1330
I'm new to this part of the forum so I'm not sure where this post would go, mods please move this post if need be.
I have an set of Cosworth WRC Zetec piston and I was told the compression is 8.5.1 is this true?
Will these piston fit into an WRC CGI block?
If so then where can I find the WRC Zetec rods and crank shaft from????
If not then I need to sell these
Old Jun 8, 2009 | 08:11 AM
BUMP
I needs answers
Old Jun 8, 2009 | 09:40 AM
grcossie's Avatar
grcossie
Have you called Cosworth ?
Old Jun 8, 2009 | 09:44 AM
alo's Avatar
alo
Hello, try putting this post in the focus section, it might get noticed.
The pistons should fit a cgi zetec block as long as bore size is correct. Try mountune ,cosworth or burtons for the rest of your parts
Old Jun 29, 2009 | 11:26 PM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
What CR does a WRC CGi Egine run?
not 8:1
what is the part numbers?
Old Jun 30, 2009 | 08:05 AM
testastretta999's Avatar
testastretta999
I use this piston in cgi block on 8.1=1, Ian Howell supplied them, he may know the spec of piston as he did have some wrc stuff i think.
Tyr his old website area6 or areasix.
Cosworth may also supply you technical drawings for the piston. I know my bike uses cosworth pistons with offset pin with longer pankl rods, and I know Ian did use longer rods in some engines.
Old Jul 24, 2009 | 08:03 PM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
it wasnt a question but a statment. WRC engine does not run at 8.1
jessie_rs
11
Jun 3, 2019 04:57 PM
neil18
Mar 14, 2016 01:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Aug 14, 2015 07:29 AM
