Whats the difference in Turbos
Hi all,
Just wondering what Turbos are available for the RS Turbo. I know you can get Hybrid Turbos made up with the 360 degree bearing in but what are the names and differences of the different Turbos. Just trying to find out as much as possible about them.
I've also heard that you can use Volvo Turbos on them and was wondering if this is true?
Dave
Dave
Stage 1
STD EXHAUST HOUSING, LARGER COMPRESSOR WHEEL, UPRATED THRUST BEARING (NOT 360 deg) -31 ACTUATOR
Stage 2
STD EXHAUST HOUSING, LARGER COMPRESSOR WHEEL, 360 deg THRUST BEARING, -31 ACTUATOR
Stage 3
LARGER EXHAUST HOUSING, LARGER COMPRESSOR WHEEL, 360 deg THRUST BEARING, -31 ACTUATOR
Stage 2
Stage 3
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
