3 DOOR Exhaust manifold
Has anyone got a detailed picture of the 3 door exhaust manifold,
Reason being the joints on mine are blowing and im told there is no gasket fitted Standard.
Its the section under the turbo.
If anyone knows or has done this job before im all ears.
I want to know about the 4 studs and if the are still for sale, gaskets if any, and most of all what is this section called??????
The bit between the actual manifold and the turbo is called/reffered to as the "trousers", as they look like them!!
There is no gasket between the trousers and the manifold but is between trousers and turbo, there are gaskets also between head and manifold.
Matt Lewis sells these 01543 484488.
As standard there is no gasket between the manifold and turbo either, the only gaskets are between manifold and head -I believe the ones mentioned by Tabetha are an aftermarket item.
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
