Oil Leak
Old May 18, 2009 | 06:13 PM
chrism_rst's Avatar
chrism_rst
Default Oil Leak
I have just been cleaning a couple of bits under the bonnet and i have noticed that my dump valve seems to be spitting oil everwhere. I have found that where the gearbox joins onto the engine there is some oil sat in that area. Would this come from the dump valve or could this be a seperate issue.
Any help would be much appriciated
Old May 18, 2009 | 06:15 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
its not uncommon for the dump valve to spit a bit of oil on an older engine imo try poping off one of your turbo hoses off and see if there is any sines of oil contamination same gose with the intercooler. it mite be a sine that your turbo is on its way out
Old May 18, 2009 | 06:50 PM
chrism_rst's Avatar
chrism_rst
thanks i will have a look and see. I suppose it will be time for a stage 3 T3 if that is the case lol
Old May 18, 2009 | 09:08 PM
RabReith89's Avatar
RabReith89
Hey mate, i had this issue on my rs turbo. Dump valve spitting oil, boost hose full of the stuff, had my turbo looked at and this was the problem. It was passen oil like no tomorrow
But bought myself a brand new stage 2 hybird Ł595 from turbo technics
Old May 18, 2009 | 09:41 PM
makaveli96's Avatar
makaveli96
What if you see oil leaking out of the oil cap what would that mean?
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
