Focus rs emission proplems!!!
Old May 18, 2009 | 05:45 PM
escort cossie's Avatar
escort cossie
Default Focus rs emission proplems!!!
Focus rs emission proplems,just took to mot today everything good untill got to do the emissions test,usually when it fails on the emissions i put fuel cleaner through it and take it for a run and that normally sorts it,this one though is way out on the carbon monoxide content,does anyone know what this could be to sort it,one thing is ive only just bought it and there is a receipt in there for a new air cleaner assembly which was put on there a few days ago,could this be anything to do with it?
Any help would be greatful!
Thanks
gavin
Old May 18, 2009 | 05:48 PM
MATT222's Avatar
MATT222
is it running a decat??
how far is it out?? e.g c.o and lambda and h/cs or just the c/o's out??
Old May 18, 2009 | 06:15 PM
escort cossie
No decat
just the c/o is out.
readings are CO 0.200% is 0.600% fail
HC 200 ppm is 81ppm pass
Old May 18, 2009 | 07:54 PM
MATT222's Avatar
MATT222
was it hot when they tested it?? did they do the full cat test or was it a quick test??
if its only the c.o thats out could point to the cat being shot!!
but i would expect the eml light to be on.
anyother questions pm me
matt
Old May 18, 2009 | 08:20 PM
escort cossie
yeah they did a full test and they retried it 5 times and it was sitting at 0.600% all the time not going much lower
Old May 19, 2009 | 07:14 PM
pdfbt40's Avatar
pdfbt40
Is it absolutely standard or has the PCM been flashed?
Done a delta temperature test on the cat ? Though as MATT222 says I'd expect the MIL to be on as it illuminates if anything coughs.
Martin
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
