compbrake
Old May 18, 2009 | 03:46 PM
samatron_123's Avatar
samatron_123
Default compbrake
hello!
are they good?
im maybe going to buy 6pot 355mm front set up. and 305mm 4 pot with seperate mecanical handbrake caliper on the rear?
im thinking about this, because its circa 2000£ for front and rear. verry cheap!
does anybody have exspirience or opinion about the compbrake bigbrake kits?
Old May 18, 2009 | 03:52 PM
KSA-Cossie's Avatar
KSA-Cossie
Got a rear kit from tony you won't go wrong with compbrake m8.
Old May 18, 2009 | 08:34 PM
miller318i's Avatar
miller318i
H676 ERL
Ive got compbrake 315mm kit on my turbo with 4 pots, very good quality, great value for money
Old May 19, 2009 | 08:16 AM
JanDK's Avatar
JanDK
335 6pots on my escort.. havent tried other kits, but they sure do work out well.
Old May 19, 2009 | 06:19 PM
rsboy370's Avatar
rsboy370
hi mate i have got 330 6 pots on my 4x4 saff very happy
Old May 19, 2009 | 09:52 PM
fezzajsy's Avatar
fezzajsy
will going for the same mate 355mm fronts.got 300mm rears already.is 355mm fronts the biggest Compbrake do?
Old May 19, 2009 | 09:57 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Couple of people I know have had problems with calipers leaking, but the prices are certainly better than some makes.
Old May 19, 2009 | 11:28 PM
hitchwest's Avatar
hitchwest
ridgey has a set of fronts and he beasts his round track he has not had any problems with his so thats good enough for me
Old May 20, 2009 | 03:29 PM
Ridgey's Avatar
Ridgey
The 4 pots are very good that i have with 335mm disk as Hitchwest says.
My experience is Very Good and the 4 pots are made by a very highly rated caliper manufacturer, and seen on some Audi A8s and 911 turbo's in the past.
Not sure if there was a praticular issue with a certain caliper type !!!!!
Old May 20, 2009 | 03:34 PM
samatron_123
does the bells have a other ofsett than the standard brakedisks?
exsample: my oz-racing wheels is now et 33, and perfect for my arches. will they after fitting compbrake kit, maybe get a bitmore out or inn?
Old May 20, 2009 | 03:44 PM
Ridgey's Avatar
Ridgey
My 8x17" wheels with a 3mm spacer are et32, and i have loads and loads of clearance.
I would have thought that an OZ racing wheel would have no issues either if 8" wide.
Old May 20, 2009 | 06:32 PM
Mike Kerbey's Avatar
Mike Kerbey
I am going to be buying a set of fronts and the rear conversion using the standard caliper. Where have you found the rear 4 pots and handbrake caliper?
yatta
Sep 1, 2015 11:28 AM
adam151082
Aug 30, 2015 08:34 AM
155lee
Aug 14, 2015 11:21 AM
Si B
97
Jun 18, 2012 05:12 PM
Arfur
13
Mar 31, 2007 04:11 PM
