turbo water feed pipe
My water feed pipe was rusty and has ended up with a hole.
Where can I get one from and will a cosworth 4x4 water feed pipe fit onto my escort rst t3 turbo?
Cheers.
Cheers.
Or you could try to get them on Ford dealers, but very expensive I bought a full set for 100 pounds last week.
The finis codes are:
T3 water cooler pipe Inlet water pipe - 6483456
T3 water cooler pipe Outlet water pipe - 1638742
Sealing washers each side of banjo bolt - 1514328 x 4no
CheeRS
CheeRS
Oct 9, 2015 07:38 PM
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
