Headlight problem
Old May 18, 2009 | 02:38 PM
Mich's Avatar
Mich
Default Headlight problem
I have one headlight working just fine and the other one has ceased working altogether I get nothing coming on at all, I had a quick look at the connecting plug at the back of the main unit and cleaned all of the connections up on that as they were filthy, but still nothing.
What else do I need to check??
If some could just give me a simple list of things to go through so maybe I can work out whats going on with it.
CheeRS
Mich
Old May 18, 2009 | 05:39 PM
If no light at all, look at the earth first, usually a bolt near the rear of the headlight holding down several earth wires(brown).
Old May 18, 2009 | 11:20 PM
cossieDavedree's Avatar
cossieDavedree
also check your getting 12v+ at the terminal of the light plug,
if not that then u need to lift the fusebox out and check the wiring to the relay and from the relay for the headlight,, obviously check fuses. I had to rewire from the relay back to the light as my nearside stopped working.
Old May 19, 2009 | 08:42 AM
Mich's Avatar
Mich
Thanks for the replies, will check those out and let you know how I get on
DAZZER
Sep 30, 2015 08:43 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
