Escort RS1600i This forum is for all things about the Escort RS1600i
rs1600i turbo running rough,sick lol
Old May 17, 2009 | 11:05 AM
supertouring230's Avatar
supertouring230
Angry rs1600i turbo running rough,sick lol
were do i start ive got a rs1600i turbo thats got a misfire and its blowing flames out the back and running rough,i dont know ifs its overfueling,injector blocked,air flow meter thing,wiring etc
does anyone have any idea wot it could be or will someone get this sorted for me as its doing my head in as i ve had the car over 2 years and could do with it on the road now.
any mechanics near wigan that wants a job doing it for me get in touch
Old May 17, 2009 | 04:28 PM
DazC's Avatar
DazC
Assuming it's on RST management, on the metering head, disconnect the 2 way plug off the side of the unit with the fuel pipes on. If it runs fine, then you have a coolant temp sensor issue. Don't drive it on boost like that though as it will have no on boost fueling correction (It will run lean).
Old May 17, 2009 | 04:34 PM
supertouring230
its a turbo technics conversion as far as i know,it as no ecu etc its running on a dizzy with standard fuel injection etc
Old May 17, 2009 | 07:08 PM
rumone's Avatar
rumone
try moving the dizzy!mine did the same sort of thing.the mark on the body should be central but not always the case!does the manifold glow?
Old May 18, 2009 | 04:18 PM
supertouring230
bump
Old May 20, 2009 | 06:26 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
You need an ecu mate.
"Slider" on the 'rsi on tour' forum has 2 for sale (one mappable) in the classifieds section.
Well worth a look, quite a few lads on here have the turbo technics conv.
If you want my opinion then id take the kit off,sell it (as they are rare now!!!) then go back to standard or whack in a RST lump.
A 16i with a turbo tecnincs will never make more than 130bhp, due the the compression ratios. any more then 7-8psi and the engine will self destruct.
Where as the RSt lump is good for 200bhp relativly easily! And a N/A 16i engine has been known to reach 125bhp anyway!
Let me know what you think/find!
big_Rad
Sep 15, 2017 09:36 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Churtz
15
Aug 13, 2015 06:40 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
turbobill
Aug 9, 2015 05:21 PM
