intercooooler
Old May 14, 2009 | 06:35 PM
gtit's Avatar
gtit
Default intercooooler
wats a good intercooler to fit? theres that many out there! wot sort of gains would i see on one of those pace ones?would prefer a big frount mount though if anyone could guide me in the right direction that wud be apreciated,
Old May 14, 2009 | 09:45 PM
nickrsturbo1990's Avatar
nickrsturbo1990
i have a radtec front mount and my temperature is always low awesome cooling system imo and im sure every1 agrees
Old May 14, 2009 | 10:18 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
yep,cheaper seems to be better!air tec and radtec for the money are the nuts!
Old May 14, 2009 | 10:37 PM
rstdave's Avatar
rstdave
Do a search on this topic mate....hundreds of threads asking exactly the same question
Old May 14, 2009 | 10:44 PM
makaveli96's Avatar
makaveli96
I agree I've got a Radtec as well.
Old May 14, 2009 | 11:03 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
airtec on mine. good quality kit and a fair price, had radtec on my old rst and again good quality and temps. I used to have a pace ic on my fez which to be honest was only a small improvement over standard
hope this helps
Old May 14, 2009 | 11:23 PM
Chopshop85's Avatar
Chopshop85
Dont waste your time with the pace!
Go for a full front mount, will be worth the extra cash! I have an airtec on mine, does its job nicely.
Old May 15, 2009 | 12:37 AM
Micky's Avatar
Micky
Can I ask the above posters what testing they've done to form their opinions???Regards,Micky
Old May 15, 2009 | 05:01 PM
dan-dan's Avatar
dan-dan
anyones coolant temp run hotter than normal with a full front mount as my s2 runs hotter with a front mount.
Old May 15, 2009 | 05:25 PM
cressy's Avatar
cressy
theres a nice big grs one here for sale mate
https://passionford.com/forum/ford-r...-breaking.html
Old May 15, 2009 | 06:35 PM
timturbo's Avatar
timturbo
grs all the way!
Old May 15, 2009 | 06:41 PM
makaveli96's Avatar
makaveli96
I've notced that too do you know why that is?
Old May 15, 2009 | 06:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Less air flow to the rad, the IC is in the way!
Old May 15, 2009 | 06:52 PM
rstdave's Avatar
rstdave
Maybe because there is a bloody great intercooler blocking the airflow to the radiator?!
smila's Avatar
smila
grs are sweet
Old May 16, 2009 | 06:55 AM
mark2's Avatar
mark2
hi
i use an airtec front mount with twin fans and it does the job well
on my act guage in london traffic it can hit 32/40 degrees with an outside temp of 20 degrees c and drops to 21 degree moving steaderly
and when booting about at 14psi under heavey driving around town stop start stop start will be around 28 degrees c and drops down to 17/20 degrees on motorway at 70 constant
when the airtec was fitted the coolant temps went up as i/c blocks airflow but i changed the fan switch to a lower operating temp one and now sits between r/m on temp and if i sit there it drops lower
i carried out the above on the hottest day this year so far 20 degrees c and will be doing more as the weather gets hotter but will only be testing the temps with the airtec and twin fans not switching back to standard ic to compare well i say that now thou
mark2
Old May 16, 2009 | 08:44 AM
dan-dan's Avatar
dan-dan
the intercooler is like a radiator its there to lower the temp, so the air passing over the intercooler takes the heat from the charged air which then gives you a higher air temp entering the coolant radiator so it cant take so much heat away. mine is ok but in heavy traffic on the M1 the temp did get to 110'c but i have a 98'c fan switch lol. it got setup resently the temp gauge hit 120'c
