LPG GAS conversions
Old May 13, 2009 | 07:15 PM
andrewg's Avatar
andrewg
Default LPG GAS conversions
anyone know much about it???
is it worth getting into???
does it mix with moddern day technoligy???
Old May 13, 2009 | 07:38 PM
105epwr's Avatar
105epwr
i fitted them a while back at a garage,there ok if you are doing the millage,work well with modern eng man you can set them up via a laptop as you have to fool the cars management for switching it on ie injectors,o2 sensors,you then splice in to the vehicles looms etc
various different ways with the fuel tanks aswell ie split tanks or fit them in your spare wheel well and so on
they say theres about a 5% power loss on gas tho.
Old May 13, 2009 | 07:47 PM
Madbradz's Avatar
Madbradz
yes small power loss.... Only worth it if you do mega mileage... I was doing 1000 miles a week so was well worth it.
Adam
Old May 13, 2009 | 11:15 PM
markk's Avatar
markk
I ran it on my LDV V8 service barge, made the van cost eefectiv enough for use daily, and i dint do alot of miles at all, the fact its over 50% cheaper the conventional fuel and you will use more per gallon than on petrol, but nothing like 50% more, the calorific value of LPG is less than petrol, so you need to burn more to get the same energy from it, i reckon on no measurable power loss, but got more like 3 mpg less on gas than on petrol, but the engines also run smoother on gas than petrol !
Old May 13, 2009 | 11:20 PM
leecavturbo's Avatar
leecavturbo
there is a lad running a evo on it because of the close ratio's motorway cruising is high rpm. iirc he said just doing a 400mile or summat not mega miles round trip saved him £100?
then can switch to fuel at the track
Old May 14, 2009 | 05:39 AM
Barry_GTi's Avatar
Barry_GTi
Aussies love it cause of the rebates they get, but from what I gether it's easier to tune with due to high octane ratings.
There is less power on LPG, no two ways about it, however that's on a dual fuel engine. I believe if an engine is setup from the start to run LPG then power is available, you can run more compression than with petrol, although you will use more LPG for the power than petrol but then it is cheaper.
The Aussies use it on turbo 4.1 straight 6 falcons. I think if done right it would be great yes.
Old May 14, 2009 | 10:41 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
my x5 is lpg and its great!
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
