Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
crank position sensor setup for my s2 efi
Old May 13, 2009 | 05:31 PM
B1G_RST's Avatar
B1G_RST
Default crank position sensor setup for my s2 efi
as above not got the older 90spec block so dont have the cps hole, can be bothered with the messing about with gearbox out again sooooo
a crank postion sensor of somesort needed
looking for th 36-1 bottom pully sensor set up or simlar,,
anyone?>
sean
Old May 14, 2009 | 10:44 AM
JokerDisco's Avatar
JokerDisco
As pm I've got the Crank Sensor, Crank Sensot bracket (shiny bling one) and the Pulley minus the trigger. Get a trigger from Jano (oddkidd) for £28
To buy they are:
Crank Sensor £13
Crank Sensor bracket £26
Pulley without trigger £25
+ postage
You can have for the lot for £50. Dont know about postage becuase the Pulley weighs a ton. You can collect if need. or i can get a price for postage
Crank sensor - used
Crank sensor bracket - used
Pulley modified to take trigger - new
let me know if your interested.
Old May 14, 2009 | 03:46 PM
B1G_RST's Avatar
B1G_RST
To buy they are:
Crank Sensor £13
+ postage
Crank sensor - used
hi mate try and get a pic up for me to look at the way the trigger fixes to the pulley cheers
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
