diesel expert needed
got a 1.8 td escort and cam belt snapped can lock the cam off and also the pump but is there another way to lock the crank without the proper pegs cheers
fella pin uses the same idea have seen people get a second blanker and weld a bolt to it can use a drill but dont undo crank pulley on it remember if engine is endura cam is not dowelled or keyed just taper fit cam locking tool looks like a piece of angle iron
The Enigma
13
Aug 20, 2015 09:38 PM
