ford focus rear brake drum damp + rear wheel spins when handbrake is on?
Old May 11, 2009 | 04:30 PM
paceo's Avatar
paceo
Question ford focus rear brake drum damp + rear wheel spins when handbrake is on?
hi guys, got a problem with my mates car - ford focus 2000 1.6 automatic.
rear brake drum is very damp with brake fluid, now i have had a look at the brake lines and flexi hoses and these are very dry, it seems as if the leak is internal.
also the wheel can be moved around when the handbrake is on. passenger side is fine, no dampness on rear drum and wheel wont budge if you try and spin it.
car looses brake fluid and has to be topped up.
any ideas what can be wrong?
Old May 11, 2009 | 04:33 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
burst wheel cylinder and contaminated shoes
Old May 11, 2009 | 04:34 PM
paceo's Avatar
paceo
i take it the cylinder is internal in the drum?
Old May 11, 2009 | 04:36 PM
focusv8's Avatar
focusv8
Yes, new cylinder and new shoes required.
Old May 11, 2009 | 04:37 PM
paceo's Avatar
paceo
you got a finis code?
i take it brake fluid will need all bleeding again?
.Ross.'s Avatar
.Ross.
Aye .. Blew the cylinder seal's ... Buy a new cylinder .. Gonna need a set of brake shoes as well .. Change both side's ...
Old May 11, 2009 | 04:38 PM
JTECH James
Passion for Fords!
ideally a pair of cylinders, hydraulic components like that should ideally be fitted in pairs, if one has failed the other wont be far off, and it also helps to avoid brake imbalance
they are dead cheap though
daveandhelenturbo's Avatar
daveandhelenturbo
its a quick easy job ive just done both rear cylinders on a focus, took me an hour to both sidea and re bleed the full system.
Old May 11, 2009 | 04:43 PM
.Ross.'s Avatar
.Ross.
Aye .. Might as well do both side as said ... Have a good look at the drums while your at it ... Get some Brake-Clutch cleaner ..
Old May 11, 2009 | 04:44 PM
paceo's Avatar
paceo
wicked mate, top class, is it worth changing the both the drums as well?
Old May 11, 2009 | 04:46 PM
JTECH James
Passion for Fords!
na, the drums will be fine, clean them up with some abrasive paper and wash out all the brake fluid deposits,
renew the cylinders and shoes,
dont forget to back the handbrake cable adjustment right off before removal, and adjust the brake adjusters before tightning the cable at the end
Old May 11, 2009 | 04:57 PM
focusv8's Avatar
focusv8
http://cgi.ebay.co.uk/FORD-FOCUS-REA...3%3A1|294%3A50
Old May 11, 2009 | 05:03 PM
paceo's Avatar
paceo
id rther stick with ford motorcraft parts than cheap tat
thak you anyway mate for looking
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
Red_bull
Aug 9, 2015 08:34 AM
Bosch
Aug 4, 2015 05:14 PM
