Escort 1.6 zetec help required again please!
Old May 11, 2009 | 10:40 AM
sambo170588's Avatar
sambo170588
Default Escort 1.6 zetec help required again please!
got a few problems AGAIN with my bolloxed zetec gonna wright a list of questions any help with them would be much much appriacted.
1.Blower does not work no air comes through even with aircon on been told its possible the resister.where abouts is is?? ive checked the fuses??
2. when start up after leaving my car theres a noise that sounds like someones dropped a few nuts and bolts in the engine. I suspect that my old coil (which was knackered) has killed the starter motor off, the reason I say this is becuase when u turn the engine off when its making this noise u can SOMETIMES not all the time take the key out of the ignition and its still turning over and making that chucking sound before start up. once its warm say after ten mins the noise goes and its fine its isnt losing any power when u drive whilst making this noise either
any ideas???
3. on the induction pipe into the engine (its a 1999 v reg so its not the alloy efi heads its the plastic manifold one) theres a a sensor on the housing about 15cm before the throttle body what is this sensor? is it an oxygen sensor and what is its purpose and how would i test is its faulty?
4. what head complete with all ancilliarys (maf,injectors cams ecu ) would fitt straight onto my 1.6 bottom end or am i wasting my time lol??
cheers for any help might one day get my car running properly
Old May 11, 2009 | 12:44 PM
The resistor for the fan motor is usually mounted on the motor somewhere.
The noise and description sounds like the starter is staying energised, not good, most likely if it is a BOSCH starter the solenoid is jamming, they normally jam and refuse to move, rarely jam in the on position, easy cure though, and it's free!!
Take solenoid apart on starter and use someold wet and dry paper oiled to clean the inside surface of the solenoid and also the outside surface of the piston in it attached to the lever/pinion assembly.
What happens is the laquer comes off the inside of the solenoid and gets jammed between piston and surrounding space.
I would imagine this sensor is the air temp sensor.
Old May 12, 2009 | 02:41 PM
sambo170588
thanks again tabetha will try them out and swap sum bits see how it goes more bloody money do u have a name lol?
JoeyBoyden
Jan 4, 2024 02:36 PM
FlashRS
Sep 14, 2015 12:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
Vincereese
Aug 18, 2015 03:57 PM
