idle problems
Old May 10, 2009 | 01:01 PM
wasted2410's Avatar
wasted2410
Default idle problems
hi i own a escort series 2 ive recently rebuilt the engine and it was running fine but for some reason now it wont idle it just stalls its fine wen its runnig, so long as u dont let the revs drop, ive tryed the idle valve and wen its adjusted its fine also to with the throttle cable, until you turn it off then it just stalls again. can anyone help cheers.
Old May 10, 2009 | 07:51 PM
I would check CO and for air leaks.
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
