breaking zetec turbo fiesta rs
hello i have to break my car as moving to oz
i have
hispec 300mm disc and 4 pot calipers £450
b&m quick shifter £165
bailey header tank £70
bailey breather £50
forged pistons 85.5mm £300
h section rods £350
ford green lighting injectors 440cc £200
cosworth inlet for zetec £200
tubular exhaust manifold £150
t34 turbo smokes and has play in shaft £150
zetec block with fresh crank oil pump and water pump £100
euro rear lights £75
bonnet raisers £10
zetec motorsport leads £45
aera 6 valve springs good for 20 psi £100
rear beam power coated purple £40
wishbone carriers same as the axle £20
vibe gearbox mounts £50
there is loads i have missed off if u need pics ask cheers jay
i have
bailey breather £50
h section rods £350
bonnet raisers £10
Billy_RS
16
Oct 11, 2025 09:41 PM
