Water Leak probelm solved
After a few hours of hunting and stripping the interior out i found the problem. I eneded up removing the lower half of the dash also
Under the battery tray i found this hole
What has happened is before i owned the car someone used a long bolt to hold the battery clamp and it punctured the lower skin. Over the winter i bought a new clamp and the correct bolt so the hole was no long plugged and thats where the water has came from
All sealed up now tho
Mark RS
Oct 12, 2015 06:01 AM
