L8 ecu HELP
i got this ecu out off my 4x4 saph ,i've just open it to put a stage 3 chip in it on a baby board. As you can see the ecu ain't got the connection for the little pug with the blue cables. Can someone tell what the is going on or what ecu it is.CAr was running fine with the ecu and standard chip in it just a bit slow.
thank lee.
http://i566.photobucket.com/albums/s...h_IMG_0191.jpg
http://i566.photobucket.com/albums/s...h_IMG_0189.jpg
thank lee.
well if you can a l8 to a 2wd then cant see a problem with using a l6 in a 4x4 would need to see if the 2 wires have been swapped on the tps just like you do when you fit a l8 to a 2wd
prob totaly wrong but thats how i see it
hth
hth
Cool so its a L6,the car runs fine on it and now its got an L8 on it with a stage 1 chip on car runs fine.I just can't get my head around it.Would a L8 work without a Knock sensor?
you have 3 options.
1) use L1 with the correct chip
2) use 'yellow' injectors
3) keep the 'blue' injectors and use an L8 with standard chip
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
ere akamob looks like you gonna be giving me my l8 back and il give you my l1 with the st 1 chip and yellow injectors
