Saph wont rev past 3k
Old May 9, 2009 | 03:45 PM
dakar's Avatar
dakar
Default Saph wont rev past 3k
Have just rebuilt the top half of my engine and painted it all up to make it look nice and put the engine back in and have got it all running.Just one problem in that it just cuts out at 3 thousand revs every time.It is ok if you rev it gently as long as you dont exceed 3k.Could it be anything to do with the phase sensor in the dizzy as i took this apart to clean and paint or will the fault be elsewhere.Any help,advice and suggestions gratefully recieved
Old May 9, 2009 | 04:49 PM
john_p_b's Avatar
john_p_b
timing?
Old May 9, 2009 | 06:13 PM
dakar's Avatar
dakar
Originally Posted by john_p_b
timing?
Timing is spot on mate
Old May 9, 2009 | 06:18 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
scrap it.................
Old May 9, 2009 | 06:26 PM
Twellsie's Avatar
Twellsie
mine has exactly the same problem, although it seems to be ok from cold, but as soon as its warmed up it happens
Old May 9, 2009 | 06:36 PM
Paul_RS's Avatar
Paul_RS
Fuel pressure reg buggered?
Old May 9, 2009 | 07:06 PM
dakar's Avatar
dakar
I think jacko would kill me.... lol
Old May 9, 2009 | 07:07 PM
dakar's Avatar
dakar
I may be wrong but i think its electrical as it cuts out bang on 3k every time
Old May 9, 2009 | 07:34 PM
cabrio zo's Avatar
cabrio zo
From: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
Could be the phase sensor, ours used to 'stutter' and not rev or boost past around 3500rpm (ok if you changed up before then) phase sensor was knackered - wires all broken up - IIRC you need to gap them too (0.2 - 0.2mm) you could've disturbed it?
Z
Old Apr 25, 2010 | 05:25 PM
Dan Higgins's Avatar
Dan Higgins
i have a 2004 ford fiesta an just put a new head gasket and oil cooler on it but now the car wont boost atall its slow as piss it wouldent pull you outa bed has any1 any ideas
Old Apr 25, 2010 | 05:33 PM
Billy_RS's Avatar
Billy_RS
Hi jacker! lol
gambo08
Feb 4, 2016 10:49 PM
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
