Cossie stopped boosting....(found out why now)
Was just out in the saph,boosting in 2nd changed into 3rd got a little boost then fook all,got it back in the garage and took off the air filter to turbo hose and when idling the turbo aint spinning but will spin when i turn it with my finger any ideas,fooked turbo ????
Exactly the same thing happend to me buddy took the turbo off to find one of the blades missing at the back of the shaft must have shot off down the exhaust
Strange question i know but does the exhaust sound any louder than normal? The reason i ask is mine sounded alot different when it happened lol
It took me an hour to get the turbo off my 4x4, you need some short spanners aswell. Hope its something silly, could you try takeing the downpipe off 1st and checking if the shaft is still in tact?
M8 has a t38 fitted and was impressive on 14 psi now peaking at 34 and is well fast.
dont bother with the stack mate. diodes will work as ive temp tried mine up to 4k and was perfect. couldnt rev more than that as car was stone cold.
made my self a nice little loom too, so i can disconnect the diodes any time i like
used alittle box to house the diodes as i wasnt sure if you could heat shrink them.
the two wires go into the coilpack plug, then just attach a wire from the last diode to the clocks
fuck it cant move the pictures
sounds stupid but you acdtuator rod hasnt come off has it
i remember when i lost boost all of a sudden car exhaust note changed and lost all power, sounded and went like a replica lol, ended up being the little clip fell out that hods the rod on and the actuator popped off
