Aeroquip/Earls fuel hoses
Old May 8, 2009 | 05:13 PM
Steve-O_RST's Avatar
Steve-O_RST
Default Aeroquip/Earls fuel hoses
Hi there,
I'm looking to replace the fuel system on my car while my engine is being built.
The engine will be running around 450 flywheel horsepower.
I'm just wondering what size of Feed hose you think is necessary, either -6AN or -8AN.
I have a Bosch 044 pump and an Alloy swirl pot setup in the boot. I'm just unsure if the -6 hose is capable of flowing enough fuel? I will be running an 8 injector setup also, if that info helps.
Another question I have, I don't know if this is this is just a rumour or not. Anyway the hoses will be ran inside the car. I've heard that if you use a normal rubber lined hose and fittings to suit, you get the smell of fuel fumes inside the car as the hose breathes slightly?
I've been told that a PTFE lined hose would be best to use as it will not breath at all.
Just wondered what your thoughts were?
The PTFE hose and more importantly the fittings are a fair bit more exspensive than the usual Aeroquip/Earls fittings as they use the olive setup etc like a brake hose would. Not sure if its worth spending the extra ££ on going for this.
Many thanks in advance! Any info is much appreciated
Cheers guys!
Old May 8, 2009 | 06:33 PM
- Sim -'s Avatar
- Sim -
-6AN will be way enough Pal
there are fuel capable hoses available, like you wrote ptfe, but these are not cheap, roughly 10 - 15 pounds per meter in -6AN
Old May 8, 2009 | 07:41 PM
Steve-O_RST
Thanks for your reply Sims
Anyone know roughly where -6AN starts becoming to restrictive? Power output wise?
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
