how can you tell diff sizes 7" - 7.5"
Old May 8, 2009 | 03:50 PM
silky16v's Avatar
silky16v
Get on That!
Default how can you tell diff sizes 7" - 7.5"
can you tell by measuring something on the outside of the diff to tell if its 7" or 7.5" as my tag is missing on my diff cover on the diff that in my kit car
I know its a 3.62 ratio and has bolt-on type driveshafts
just need to make sure i'm ordering the right size LSD diff thats all
Old May 8, 2009 | 03:53 PM
slydawg65's Avatar
slydawg65
measure the top of the diff, where it bolts into the bell housing.
Old May 8, 2009 | 04:02 PM
silky16v's Avatar
silky16v
Get on That!
as in the part on top that has a great big long bolt going threw it
Old May 8, 2009 | 04:03 PM
slydawg65's Avatar
slydawg65
thats it mate. what car is it??
Old May 8, 2009 | 04:05 PM
paul16v's Avatar
paul16v
Monte 087
iirc the 4wd diff uses 2 long bolts top & bottom whereas the 2wd just has 1 long bolt at the bottom & at the top the diff casing is tapped for short bolts.
Old May 8, 2009 | 04:15 PM
silky16v's Avatar
silky16v
Get on That!
diff is in a kit car
Old May 8, 2009 | 04:16 PM
silky16v's Avatar
silky16v
Get on That!
arh cool knew there was an easy way to tell mine has the long bolt on the top side so is a 7" which is what i thought it was
Old May 12, 2009 | 10:51 AM
Jamie@FastFord's Avatar
Jamie@FastFord
Jamie @ Fast Ford
Another quick way to tell whether it's 7 or 7.5 inch without taking any bolts out is to look directly at the diff from behind, on the top left there is a hole machined into the casing. On a 7.5 inch diff the backplate extends to cover this and also has this hole machined in it, whereas on a 7 inch diff the backplate doesn't extend this far.
boeb
Jan 9, 2020 05:11 AM
Iain Mac
Sep 30, 2015 09:39 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
DavidK
Sep 27, 2015 02:55 PM
