had an operation, and my cut is still very hard!
17 days ago guys i had a minor operation with a lot of dissolveable stitches, now where i have been cut open its rock hard skin, will this soften out do you know? just wondering as its not confortable being hard, any creams around to soften the scar tissue or is it too early to call?
Beccy had a very small cyst removed from her back at the beginning of March, you should see the scar. Looks like she had it done last week and what a fucking mess they made of it too, as though Edward Scissorhands was the surgeon.
Lovely considering we get married in 4 months and it's where her shoulder blade is.
Moral is, don't panic, it could be worse!!
Bio-Oil works best when it is used from when the scar is reasonably fresh Benni, so you may not get fantastic results! BUT i have also used it on older scars, and they have dramatically smoothed out!
Know that feeling, you should see the one on my back from having a mole removed last year!!! right in the middle of my back between my shoulder blades and its stretched to fuck now!! the gf said she can stick her hole thumb in it!! Will try get some pics if poss, as maria said it will soften up in time and bio oil does help but its not cheap!!!
Still got a scar across my throat from when i had my thyroid out, that stretched alot too!! unfortunatly unless its done somewhere with little movement/stretching they all seem to get stretched out
I had dissolvable stitches in my hand and 4 did'nt dissolve. I had to go back and have them removed and F me was it painfull as my wound started to heal over them.
Its about £14 for a small bottle iirc, but does last quite long!
Bio oil is good, BUT cica care gel sheets are better in my opinion. They are available mainly by prescription and thats the cheapest way of buying them as each sheet costs about £38
so the prescription charge is cheapest way to get them!!
Ive used them for a long time for working on keloid scarring i had on arms and they are good for use on fresh scars and even old scars will flatten and not look so red and raw.
They arent the easiest things to use as you have to keep the sheet in place for hours and hours each day so sometimes you need a small tubigrip type bandage to keep it in place under clothing etc.
Its like a sticky jelly:
so the prescription charge is cheapest way to get them!! Ive used them for a long time for working on keloid scarring i had on arms and they are good for use on fresh scars and even old scars will flatten and not look so red and raw.
I had similar about 18 months ago, got told to massage it to break it down.
I just put finger and thumb either side and sort of rolled it between them
There was one bit where I had a drain in that stayed hard a while longer, but the whole length of the scar is fine now, barely visible
Try that if you don't want to lash out on the expensive stuff
Neil.
Neil.
i was told to not use bio oil until my stitches had healed, massaging the stitched area helps break down any scar tissue build up too, which was something else i had to do after my breast reduction.
Sarah
Sarah
how long was you massaging for roughly?
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
