whats this turbo?
Old May 6, 2009 | 12:32 PM
corsa-xe1's Avatar
corsa-xe1
Default whats this turbo?
hi guys, i was told its a t34 but is it?
numbers on the turbo are
s/n da170005
tb03
713333-2
ojo424
has a 3 bolt flange on the exhaust housing!
also the wastegate is not on the exhaust elbow its on the housing!!
i have some pics in my other thread!!
thanks ash
Old May 6, 2009 | 05:17 PM
tb03 is T3, my T3/34 has a 3 bolt exhaust housing, these will bolt to the core(bearing housing) which is common to T3 T34 T4, so not a clue, it is easily identifiable by the inlet of the compressor housing as it is much larger on the T34 than the T3, unless it is a T3 compressor housing machined out to take a T34 trim(like mine).
Old May 6, 2009 | 07:38 PM
corsa-xe1's Avatar
corsa-xe1
ok thanks mate
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
