Turbo for stage 3
Old May 5, 2009 | 06:42 PM
Wull79's Avatar
Wull79
Default Turbo for stage 3
I have decided its time to up my cars power to stage three as my standard turbo is at the end of its life, i have the injectors etc but no turbo or chip, i know most people fit a t34 with a .48 housing is there any other options have had a t35 mentioned but not sure what the difference between a 34 and a 35 is cheers
Old May 5, 2009 | 06:59 PM
Different people call them different things, but to most a T34 and a T35 are the same thing.
A T34 is a large turbo escort cossie size.
You would do well to consider having basic mods done at the same time as new or rebuild, such as a 360 bearing is a must for longer life than the std 270 affair.
The turbine housing size will have a major influence/impact on how it drives, ie smaller boost earlier, but ultimately won't produce as much power, but if it's doing as much as you want power wise then a smaller one makes a nicer car to drive all the time, especially off boost.
You could go roller bearing for even less lag, but price is a lot more, so consider carefully the characteristics you can live with, for me I like it in nice and early so it is better off boost, so have a .48 housing, I have a T34 compressor trim in a machined out T3 housing, works well for me.
Old May 5, 2009 | 07:13 PM
cossieDavedree's Avatar
cossieDavedree
have you got a rs500 type cooler though? Cos you'll need one if you don't have one depending on the boost you run
Old May 5, 2009 | 07:25 PM
Wull79's Avatar
Wull79
Cheers i have a 500 cooler fitted already and i had a top end rebuild done a few thousand miles ago with a groupA headgasket
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
