Petrol cooler ?
Old May 5, 2009 | 02:27 PM
FQ200turbo's Avatar
FQ200turbo
Default Petrol cooler ?
just thinking... will a petrol cooler helps to avoid (a bit) detonation ?
tks
Old May 5, 2009 | 05:44 PM
I was thinking this the other day too.
Theoretically yes I suppose as charge will be cooler as fuel absorbs some of the heat from the air ?
Old May 5, 2009 | 07:52 PM
JonathanJ's Avatar
JonathanJ
It would in theory be better , in aircraft air cooled petrol engnes they inject more fuel and rely on its latent heat of evaporation to aid cooling , another method is to increase fuel flow and cool the tank and rely on the fact that the fuel can only spend so much time picking up the heat on its journey to the fuel rail , guess you could try using something to drop temp in the way to rail and see if it worked .
Old May 5, 2009 | 09:07 PM
FQ200turbo's Avatar
FQ200turbo
thats also an idea
alot of new diesel cars have stock diesel coolers, but they dont suffer detonation
timsrs
Nov 13, 2018 11:48 AM
gcfcos
59
Oct 6, 2015 05:04 PM
