How is boot fuel cut off wired up????
Old May 5, 2009 | 06:55 AM
rog's Avatar
rog
Default How is boot fuel cut off wired up????
Well, on the long list of "Stevey Wonder & Co Auto Electricians" work on a cossie I just bought the fuel cut off has been disconnected, it's still in the boot rolling around and two wires poking out from under the boot, but how does this connect into the cut off????? Basically i need to sort all this out and make the car "safe" as it's just a complete mess.
Any help greatly appreciated, especially pics and diagrams.
Old May 5, 2009 | 08:40 AM
It's very simple, it's just live in and live out, the cut out is vibration sensitive, so just screws under the metal bracket, held with two long screws, connector plugged in then wires(2)goes through boot floor in the pump feed line to cause a break, so just find where it has been taped up, untape find the ends where it's been cut, and rejoin into the cutout, then if tripped the pump feed with terminate at the cutout, a simple depress of the white button on top reactivates it.
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
YODI
Aug 30, 2015 01:12 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
