anyone help
Old Dec 6, 2004 | 08:35 PM
rslad1985's Avatar
rslad1985
Default anyone help
how hard is it to change a headgasket on a erst can it be done in a day? any special tools needed?
Old Dec 6, 2004 | 08:46 PM
chummer's Avatar
chummer
not hard and can be done in a couple of hours , udo need to make sure u keep the timing , best way is to mark the vernier pully with a marker , also idealy u need new head bolts and the only special tool is a torque wrench
Old Dec 6, 2004 | 11:06 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
also need to get the head skimmed (probably)
Old Dec 7, 2004 | 12:12 PM
rslad1985's Avatar
rslad1985
yeah a mate said summit bout the head getting skimme. how much is that roughly
cheers guys
Old Dec 7, 2004 | 12:15 PM
rslad1985's Avatar
rslad1985
anyone the know the torque settings for the car?????
Old Dec 7, 2004 | 01:31 PM
vroooom ptssssh
It Wasnt Me!
bout £30 -40 for a head skim i THINK.
torque settings:
Stage1 25nm 18lb/ft
stage2 55nm 40lb/ft
stage3 tighten by a further 90degrees
stage4 tighten by another 90 degrees
(by stages it means do the head bolts in the correct order, then 2nd time, 3rd time, 4th time )
p.s. use NEW headbolts, NOT the old ones.
