cossy solid lifters ???
Old May 4, 2009 | 10:17 AM
forevaford's Avatar
forevaford
Default cossy solid lifters ???
hi guys i have got a 4x4 saph and is aiming for a revy 450 bhp
iv decided to go for solid lifters, i will be seeing close to 8k rpm. however i hear stories of using ford 1.8 diesel ones with the shims at the top. how compatable are these for that kind of rmp?
i got double valve springs, but are they still too heavy? last thing i want to do is loose a shim!
also iv herd of converting standard hydrollics to sollid with a piece of small steel rod fitted to the middle (shimed to length obviously)
any advice would be apprieciated
thanks ....mart
Old May 4, 2009 | 10:26 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
contact AUTOSPRINT .they advertise in the ford mags.
http://www.autosprint.co.uk/
Old May 4, 2009 | 10:36 AM
forevaford's Avatar
forevaford
thanks will do
Old May 4, 2009 | 03:48 PM
DazC's Avatar
DazC
Yes the 1800 diesel and VW buckets can be used.
Old May 4, 2009 | 04:13 PM
JonnyBravo's Avatar
JonnyBravo
I use Arrow solid lifters in my engine, Autosprint supplied my valves though
Old May 4, 2009 | 06:46 PM
forevaford's Avatar
forevaford
cheers guys, i mite give arrow a call, im still interested in the ford diesel ones tho??? im just curious about valve float issues or worse a shim cumming out!
Old May 4, 2009 | 07:06 PM
forevaford's Avatar
forevaford
have you got a contact number or web address for arrow?
Old May 4, 2009 | 07:17 PM
JonnyBravo's Avatar
JonnyBravo
PM Steveboyslim on here
Old May 4, 2009 | 07:55 PM
DazC's Avatar
DazC
If they're shimmed correctly then they can't come out. Otherwise the diesel would have the same issue.
The boost pressure is more likely to be an issue rather than the slight increase (if any at all) in weight over a hydraulic item.
Old May 5, 2009 | 10:14 AM
forevaford's Avatar
forevaford
ummm, ok. i was thinking the almost double rpm mite have an effect, its mainly the weight issue im mostly concerned about. pehapps i need to weigh both items and decide from their...
thanks for the info guys
Old May 5, 2009 | 10:39 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Are you planning on using them?
Old May 5, 2009 | 10:58 AM
forevaford's Avatar
forevaford
its bad to say on a cossie espesially but i want to keep it cheap for now as i wanto grind the shims my self, and theirs plenty of room for error, but im tryin to contact various places to see what they offer. Newmen cams hav a set of easy adjust lifters???
im still interested in the ford diesel ones tho, im gonna go down the scrappy and retrieve a set to piss about with i think. Mainly to compare the weigts, and to see how far the shims are out
Old May 5, 2009 | 10:59 AM
forevaford's Avatar
forevaford
i have tried to google arrow cams but with no success, i cant find a contact number for them.
Old May 5, 2009 | 11:04 AM
Chip's Avatar
Chip
Arrow cams isnt the name of the company.
www.arrowprecision.co.uk
Old May 5, 2009 | 11:06 AM
forevaford's Avatar
forevaford
lol cheers dude
Old May 5, 2009 | 11:23 AM
forevaford's Avatar
forevaford
270Ł for arrow precission lifters, wot the deal with the stems?? do i need a stem or not, i aint replacing my valves....
Old May 5, 2009 | 12:01 PM
JonnyBravo's Avatar
JonnyBravo
Yes mate, already built up in the head.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
