Saph diff help!
Old May 4, 2009 | 09:57 AM
avinit1rs's Avatar
avinit1rs
AV IT!!!
Default Saph diff help!
Hi there, i have a 2wd saph and have taken the back plate off of the diff, can anyone tell me if there is suppose to be a gasket between the diff and the back plate as mine does not seem to have one of any sort. Also whilst the cover was off i checked inside and the oil is very dirty, i have removed the oil but there are still bits inside which i cant get to, what can i clean the inside out with without taking it all apart.
any suggestions? cheers.
Old May 4, 2009 | 06:19 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
anyone?
Old May 4, 2009 | 06:49 PM
p285e's Avatar
p285e
Hello,
You can clean it with a grease remover like "tix", You haven't any the gasket between the diff and the back plate, you can use a good quality silicone of a sealant like the Curil T ( green )
Sorry I can't give more explaination because I haven't enough mechanical vocabulary
and I'm come from Belgium
I hope that's help you
Eric
Old May 4, 2009 | 06:54 PM
p285e's Avatar
p285e
A detail don't forget the oil, LOL
use a good quality limited split oil, Mobil 85W90LS for example
Eric
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
