Pro alloy turbo cooler?
I'd get the Airtec one only cost around £78 posted, i personally cant see why not to get one, unless you dont have much money, i brought mine while rebuilding my RS back up. so i aint drove the car yet but it must be worth it driving around the busy roads in swindon.
The posh are up!!!
Exactly i restored my s2 from ground up, when i got it set up by harvey gibbs he mentioned to get a new fmic and look into a turbo cooler, my s2 is a everyday car now.
Passionate about fords
oil cooler ????. your all on about the cooler that cools the water coming out of the turbo before entering the rad arent you ????. the one which sits beside the pro alloy fmic.
dave.
dave.
Dont see the point in a tiny extra rad cooling the water before going into the main rad? Although I spose every little helps!
Ok i'm completely wrong! lol
"This neat little cooler is designed to bolt to the end of our PRO ALLOY front mount intercoler and replace the air scoop which we supply as standard. The purpouse of this unit is to cool the water as it exits the turbo, before it is returned to the water radiator."
Myself and a lot of other people dont run the water cooling on our turbo's to keep water temps down.
Just have to make sure we idle our cars for a minute or two before switching off to prevent heat soak in the turbo and cooking the oil.
I cant personally see the point of trying to cool the turbo with water anyway, how can you cool a 600+ degree turbo with nearly boiling water
Ive never run water through a turbo
As a Turbo Cooler I think it's pointless (as it doesnt cool the turbo!), but maybe just as an extension of your rad it cant hurt, extra cooling is always welcome.
Yes Rob they did, and they were praised for the price of what they do. if only for a few degrees.....if you dont have money to splash out on stuff like this then dont bother, but any RS owner should have money to throw it at.
just like a dump valve you lot all say you dont need them !!!but if you just spent £1200 on a roller bearing turbo and didnt run a dump valve or the water you would be most upset when it fucks its self. so i run both but each to there own
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
Matt Baxter
Sep 16, 2015 08:30 PM
