all you efi guys.
Old May 2, 2009 | 05:06 PM
stevenebm's Avatar
stevenebm
post whore
Default all you efi guys.
doing away with my mfi for gotech on my s1.question bout fuel line.fuel filter outlet.where to then?do i need a fuel pressure regulator and if so what am i looking to set it at and then from this to injector rail?
Old May 2, 2009 | 06:12 PM
morph's Avatar
morph
I beleive that the fuel rail which you will have to use, either a frst fuel rail or a cosworth fuel rail has the FP regulator on the end of it.
Old May 2, 2009 | 07:02 PM
Chris69's Avatar
Chris69
as above it just goes to the fuel rail from the frst or similar
Old May 2, 2009 | 07:05 PM
mad dog younge's Avatar
mad dog younge
if your doing away with mfi wot inlet are you going to use .cos the frst inlet with have every thing you need
Old May 2, 2009 | 07:07 PM
ollie240585's Avatar
ollie240585
Just doing the same thing myself.
Been building my head up today.
The fuel pressure regulator is at the end of the injector rail, its the thing i've got attached to the inlet manifold with a red silicone hose.
Just remember if you're attaching this to an MFI head you will need an adaptor plate as the ports do not line up correctly. Here's mine which i've been doing today.
[/QUOTE]
Old May 2, 2009 | 08:58 PM
stevenebm's Avatar
stevenebm
post whore
i have got a jamsport inlet guys.so the fuel hose will go to the connection underneath on the regulator.what bout fuel return.i have a connection on the left hand side of the fuel rail just like the one above.take it its that one.cheers for the info guys.
Old May 2, 2009 | 09:17 PM
JesseT's Avatar
JesseT
No no no.
The fuel goes from the filter to the fuel rail and will return via the pressure regulator to the tank.
Old May 2, 2009 | 09:23 PM
stevenebm's Avatar
stevenebm
post whore
ah right.sorry i thought the fuel would have to go through the pressure regulator.so it actually goes in to the connection on the left hand side of the fuel rail and then will return via the connection under the regulator.
Old May 3, 2009 | 09:40 AM
Chris69's Avatar
Chris69
exactly that
mk1turboestate
Dec 2, 2015 08:31 PM
griffo69
Sep 26, 2015 04:23 PM
Dahl88
Sep 16, 2015 10:50 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
