Aftermarket rev limiter
Old May 2, 2009 | 03:50 PM
BRAMMER's Avatar
BRAMMER
Default Aftermarket rev limiter
I'm looking into purchasing an after market rev limiter (omex) but do i need a single or twin coil item ?? - i know FRST 's run twin and i'm running wasted spark coil pack kit so is it the same??
Old May 2, 2009 | 08:01 PM
On a four cylinder twin and coilpack are one and the same, just with a coilpack it(both double coils) is all in one housing instead of two seperate doubles that's all.
Old May 2, 2009 | 10:12 PM
BRAMMER's Avatar
BRAMMER
So i need the twin coil item then tab??
Old May 3, 2009 | 03:57 PM
Yes twin coil, single coil one will only be able to cut one coil, so you must get one for twin coil so it can cut both sides of the coilpack.
The centre of the coilpack plug is live, terminal either side is the negative for the cylinders 1+4 plus 2+3 respectively.
Old May 3, 2009 | 07:56 PM
BRAMMER's Avatar
BRAMMER
Cheers Tab
Old May 4, 2009 | 04:27 PM
bad boy rs's Avatar
bad boy rs
recently fitted one of these to my saph as the chip i had had a raised limit, to be honest bit dissapointed with the omex single coil one, works fine but when you hit the limit it sounds like a wet fart rather than a nice loud bang. Out of intrest what should i be limiting it at have it set to 6500
Old May 4, 2009 | 05:43 PM
Depends really, if on std cams little point going past about 6500/6600 as power starts to drop off about there.
Think I would rais eit a bit to around 6800 so you get to fully use up to that point.
Yours may not have a loud bang if it is a soft cut one, on my ecu I set my soft cut at4000, and my hard cut at 4500, on one of my maps, great for flames pops bangs etc seriously loud, but found it kills the plugs, using IK27's it's too costly!!
Old May 4, 2009 | 05:53 PM
bad boy rs's Avatar
bad boy rs
ive played around with the soft / hard and to be honest theres no difference, maybe im not doing it right and its going back to soft cut each time
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
