erst lowering
the suspesion on my s2 has been slamed by th prevos owner, its got gaz adjustables on it ,there is no movment in the suspension at all. i brought some 35mm lowering spings to get it sitting higher and level but the car stayed the same slamed and no movment. can anhy one help. cheers
it is only realy low at the rear, i had a think bout it and thought that becuse its got the adustalbe suspension. that it might be stuck on the hard setting ant not letting the springs free
so then you only need to change the spring as the shock does not change the ride height then!
easy job that! they literally pull out once the car is jacked up in the air.
they cant be adjusted though, only change them for different springs.
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
