S2 drivers side drive shaft.
Old Dec 6, 2004 | 01:17 PM
timb551's Avatar
timb551
Default S2 drivers side drive shaft.
Hi i need to get the drive shaft off so i can replace the gaiter. How do i do this? Does it effect the ABS belts?
thanks
Old Dec 7, 2004 | 08:18 AM
timb551's Avatar
timb551
UP
Old Dec 7, 2004 | 11:35 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
undo hub nut, top strut, and tie bar, chap it out, or at worst use a press. abs belts jus slip off, jus makesure their bk on when you put it bk together.
Old Dec 7, 2004 | 12:31 PM
timb551's Avatar
timb551
when to say chap it out, you mean?
Old Dec 7, 2004 | 12:45 PM
vroooom ptssssh
It Wasnt Me!
get summit like a chisel, but with a flat end either end, hit it against the shaft to knock it out the hub, if it doesnt wana come out, or jus pull the bottom of the hub watch it dont come out the gearbox tho if u dont want it too
Old Dec 7, 2004 | 01:15 PM
Hrsturbo's Avatar
Hrsturbo
Check the condition of your ABS belts while your there and don't get any oil on them!
Kam B
Sep 24, 2015 10:40 AM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
rsturbo27
Sep 5, 2015 05:08 PM
