Mk1 Mondeo 4x4 conversion & bits
it includes:
- prop and rear diff
- rear hubs (with disks/calipers/ABS-sensors etc for rear disk conversion)
- rear shocks/springs
- fuel tank and wiring
- centre straight exhaust section
- drive shafts
- gearbox mtx75 5-speed manual
- transfer box (with bolts)
- rear sub frame (this has been shot blasted and painted black)
all the bits were removed from a mk1 mondeo 2.0 4x4 (alot of work to remove all this!) and its been garage stored for the last 18 months or so. the whole lot will fit into a mondeo hatchback for transporting.
the only bits missing from the conversion is the rear control arms (cos the ones on the donor car were fooked) but they are cheap to buy new. also a short section of prop is missing, but i was going to get a straight through prop made up (instead of having it in 2 sections like ford did)
looking for £250 for the lot. collection only, from near cambridge (cambridgeshire)
here is pics of some of the bits (i havent photographed everything yet because some of it is up my garage loft and i havent had time to get it down to take some pics)
transfer box:
rear shock/hub etc
rear diff
prop & diff
fuel tank
rear subframe
- drive shafts
transfer box:
rear shock/hub etc
rear diff
prop & diff
fuel tank
rear subframe
saph in dorset
Aug 14, 2015 10:10 AM
