FRST engine rebuild
Old Apr 27, 2009 | 08:10 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
Default FRST engine rebuild
ok folks, as mention in GD, my cambelt snapped today, so, an unplanned rebuild is about to begin........
spent the afternoon stripping it down to see the damage
rocker cover off, boost pipes off
the start of a boot full of bits
head off, just one bent valve, but will replace them all i think, peace of mind and replace the tappets and the valve stem oil seals whilst i'm at it
number three is scorched/burnt and also had a slap on it from the bent valve
one of the three snapped bolts
the bolts left in the block
headgasket was ok though
tomorrow i'll be stripping the head and deciding what to do in regard to the pistons, new or not...........
Old Apr 27, 2009 | 08:31 PM
murfs frst's Avatar
murfs frst
shame your belt let go,how you going to get the head bolts out,good luck with it tho
regards tim
Old Apr 27, 2009 | 08:41 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
i know a guy who specialises in removing bolts from anything, not cheap though, unless i decide a new block is a better option.......
Old Apr 27, 2009 | 09:19 PM
smitsturbo's Avatar
smitsturbo
why not drill a hole right in the centre of the bolts then get these things called eazy outs (cost buttons) & do it yourself??
Old Apr 28, 2009 | 02:05 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
managed to get out one of the snapped head bolts but the other two aren't shifting for fook all..... so, just off to see the man that can remove them....
smits, i would look at drilling them out, but knowing my luck at the min, would prob make a right mess of it, so, as i'm not all that sure about removing them, would rather my guy do it that specialises in it........
providing they come out, no need to look for another block, which i'm having a wee look for now.......
will update the pics later on when i get home
cheeRS
Old Apr 28, 2009 | 02:23 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
if the bottom ends fine jim , just get the treads out fella ,
overhaul the top and job done
ive got spare cvh valves , and a set of unused headbots if you need them fella,
dont need them now im going cossie powerd lol
beef
Old Apr 28, 2009 | 05:53 PM
RickDraper's Avatar
RickDraper
Drop a Zetec turbo in, wanger, job done.
Old Apr 28, 2009 | 06:39 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
nah, keeping it standard..........
head stripped and valves been ground, but need cutting and reseating
head been sent off for skimming
will put the pics up when i find the lead for the camera, i put it in a safe place and can't find it now.....
Old Apr 28, 2009 | 07:01 PM
orionmojo's Avatar
orionmojo
if you need any efi bits mate, give me a shout. i collected parts for an efi conversion on mine that went abit stale and now they're just sat there.
Old Apr 28, 2009 | 07:36 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
beef
i've been following your build in the mag and on here, good luck fella!
may just take you up on that offer pal, how much you want for them, are they new vavles or from a previous build??
piston 3 is burnt proper, so think its had it, so will be replacing at least that one
cheeRS
Old Apr 29, 2009 | 12:03 PM
Rs Adz's Avatar
Rs Adz
gutted about the belt hope it comes back bigger and better
Old Apr 29, 2009 | 07:27 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
update time
well, found my lead, so can upload yesterdays pics, not been able to do any more today as head has gone to be skimmed and have my guy coming tomorrow to hopefully (fingers crossed) remove the 2 remaining headbolts that snapped.....
nice and clean
all the valves out
all my bits and bobs removed from the head
the valves when they were removed
and after they've been tidied up
ordered some goodies today too, so will post up when they arrive
Old Apr 30, 2009 | 09:23 AM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
off up the workshop again now, meet witht the guy coming to hopefully remove the snapped head bolts.....
fingers crossed guys and gals
Old May 17, 2009 | 12:53 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
update time, well, i have finished the build, kept forgetting my camera-d'oh, have done around a 120 miles since the rebuild, and all seems to be fine, apart from the exhaust knocking on the hand brake bolts under the car, will post some pics up of the finished article as i chose to do a little painting whilst it was all in bits and tidy up of wiring whilst i was in there too.
will get out and take some engine bay pics once it stops p1ssing it down
Old May 17, 2009 | 07:04 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
ok, so i managed to get some pics in between the down pours
went for some crackle finish on the rocker and cross over
whilst everything was apart managed to get a coat of paint on the gearbox and the block
as i snapped the bolts in the heat shield and it was looking tatty, heatwrapped the manifold and down pipe
cheeRS
Old May 18, 2009 | 09:31 AM
murfs frst's Avatar
murfs frst
looks nice,where did you get the crackle paint from
Old May 18, 2009 | 11:41 AM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
got it from burton power pal, about 8 quid a can
cheeRS
Old May 18, 2009 | 06:57 PM
murfs frst's Avatar
murfs frst
cheers mate might have to get some.
Old Jun 3, 2009 | 03:19 PM
jonny s2's Avatar
jonny s2
You gunna leave total standard mate? And do just cosmetics?
Rstar_man
143
Jul 20, 2020 11:16 PM
bigryrs
Fiesta RS1800/RS Turbo
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
