Will a Piper cam pulley fit a kent cam
Old Apr 27, 2009 | 05:01 PM
fiesta_rsturbo's Avatar
fiesta_rsturbo
Default Will a Piper cam pulley fit a kent cam
As title will the piper pulley fit on my kent 35 cam?
Thanks
Old Apr 27, 2009 | 05:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes all cam pulleys will fit any CVH cam shaft mate.
Old Apr 27, 2009 | 05:13 PM
fiesta_rsturbo
Thanks very much!
Old Apr 27, 2009 | 06:41 PM
Oranoco's Avatar
Oranoco
I concur with Karlos. I ran a Piper vernier on my Kent cam
Old Oct 23, 2009 | 12:51 PM
hineho87's Avatar
hineho87
sorry to jump the thread. but is this the same for all cars? iv got a 1.8 focus blacktop? wud i get the same gains usin piper pulleys wit kent cams? also wud it be a waste of time runnin kent cams wit std pulleys?
Old Oct 23, 2009 | 07:52 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
all makes will fit on respective engines.
the woodruff keys are all designed to be the same as oem, so all makes of pulley can fit.
so piper/obx/kent etc will fit any of the cams installed, if they are specified for that engine.
Old Oct 24, 2009 | 09:41 AM
You don't automatically get any gain at all with running a vernier, mostly on std cams dialling around either side of std will do little if anything for power.
They are more suited to more aggressive cam profiles, the power point can be shifted around by moving timing even on std, but makers are pretty spot on these days, I wouldn't even consider one for a std engine/cam.
Old Oct 24, 2009 | 04:34 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
/\ good points, but i think it's worthwhile thing to make sure you get the best out of a cam as the cam belt isn't always spot on and can throw the cam out a couple of degrees.
Old Oct 24, 2009 | 05:20 PM
hineho87's Avatar
hineho87
thanks for the replies! think im stickin wit std pulleys now as garage i spoke to said if they set cams up rite they will be ok wit std pulleys
Old Oct 24, 2009 | 05:21 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
they can only set them up right with adjustable pulleys!!!!
Old Oct 24, 2009 | 05:34 PM
hineho87's Avatar
hineho87
oh rite! i dont really no wot im on about lol. so is it worth jus fittin cams wit std pulleys?
Old Oct 24, 2009 | 05:42 PM
Karlos G's Avatar
Karlos G
Balls Deep!
In my experience even with an aftermarket cam (Piper 285T), tuners I have used have left it set a 0, pointing out that on a single cam engine you are just moving the power band up or down the rev range............ so YES you may gain a few extra BHP by tweaking it but it WILL be at the cost of off boost torque and response.
IMO unless your chasing BHP figures and another 5-10bhp is that important to you i'd wouldnt bother.
Also IMO on a CVH when you reach say 220-240bhp (genuine bhp!) to get any more you are always sacrificing off boost response/drivabilty.......... Big valves/ports, Big turbo, Low comp, Cam timing, etc....
Just my thoughts...
Old Oct 24, 2009 | 07:22 PM
It's certainly going to be within 3-4 degrees of dead, so will be fine not using vernier, I wouldn't go any more than 4 degrees out from true.
Old Oct 24, 2009 | 07:29 PM
XR2's Avatar
XR2
Thanks
The KENT cam will be heavily offended by using a PIPER pulley
Joking
Any CVH Camshaft will fit any CVH pulley. Standard, aftermarket, Tuning - it's all the same.
RUBY123
Oct 22, 2023 12:04 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Sultzi
12
Aug 16, 2015 01:08 PM
mpilk
Aug 12, 2015 09:40 PM
